troy
On a flat highway going 55mph in 5th gear my tach reads 2000 rpm. I know that some guys can go 70 at 2100 rpm. My tires are 285/70/16. I dont know if the recent owner regeared the truck. But I think this is a little high. I do know that he was running 35" tires . i recently bought a set of 22x11 rims. They have 37x13.5 toyo m/ts but 2 are worn and need to be replaced.
I dont know if i should buy 2 more 37 tires or buy a whole set of 35s due to the question of what gears are in the differentials?
Would any of you be able to calculate if these are just the stock gears or aftermarket? I dont want to drain and remove the diff. covers to read the numbers . the truck has a 5spd tranmission, 5th gear being the OD and it is 4wd
