greythorn3
wheelordie.com
looking good! hey can you post more info about the 19.5 load range f tires.. i want a large tires that is good highway tread on my truck since its a tow rig.
ray
ray
Chris what you have will work. The dually extensions will work with that axle.my question is since this is a srw front axle can i use the hub/rotor combo and just bolt my dually extensions on over the hub, or am i going to have to find something different?
chris
looking good! hey can you post more info about the 19.5 load range f tires..ray
Chris what you have will work. The dually extensions will work with that axle.![]()
Goldie has the same setup.
Just takes a little time to get them on there cause ya gotta use a boxed end wrench to tighten up the lug nuts.
Lookin good dude!
Chris if you don't want this here I'll start a new thread.
BTW, You've got a great start on what sounds like a very nice build. Good luck with your project!
Thanks,
Paul
It should. If yer able to get a pic with the wheel off I could prolly tell better.lug nuts? the extensions on mine are tapped and a bolt passes through the rotor and hub. shabby pics, but here they are 1st is of the outer flange to the wheel. 2nd is of the hub/ extension. will it still work?
chris
thanks man, i'll pull the wheel tommrow for better pics. if they wont work, im thinking about using these
AA-4 http://www.arrowcraft.com/arrowcraft.php?pageid=products&subpid=catalog&category=3&pagenumber=1
or these
ACAA-4DD http://www.southwestwheel.com/store/p-1919-acaa-4dd.aspx
i think there the same thing, just different prices
chris
