86 clutch fork
Weldingman
Pennsylvania
I got my clutch replaced over the summer and the pilot bearing has been squeaking ever since. It’s driving me nuts and from the research I’ve done it’s the clutch fork isn’t applying enough pressure on it and it’s just barely making contact causing the squeak. Seems like the fix is to swap out to a new clutch fork but I can’t seem to find one?? Any help or a fix to this problem?
ih8minimumwage
Eugene, OR
Should be able to pop the clutch fork out and see what's worn (also check the pivot ball). Read about some folks building back up with a welder, so should be able to fix it yourself until new parts are available.
dogdanblue
