84 wiring HELP
Red coyote hunter
Michigan
I have a 84 f250 with a 93 7.3 turbo idi.I'm trying to clean up some creative wiring from the guy I got it from.And can not find out what wire color I need to trigger the start solenoid.I am not real fond of the under dash push button.I find either diagrams for a gasser or the wrong year,HELP.
theguruat12
Certified Tinkerer
Albuquerque, New Mexico
Those might help.... I'm pretty sure on my 85 that the wire is red. (The diagrams are for an 85 as well)
Ford always used a red/blue wire for the start circuit. It starts at the ignition switch, goes through the neutral safety and or clutch switch, and then runs out to the solenoid on the fender.
Red coyote hunter
Michigan
Tracked the red/blue and found the neutral switch was bad so the previous owner just added a push button instead of fixing it the proper way.Thanks again for the help.
