8.3 cummins dt466
88beast
pa
how big are these motors? in size and weight?
also what med duty trannies are out there for them?
thanks
nevrenufhp
torque ******
Sacramento
Besides really freakishly big for a pickup?
The 466: 29" from oil pan rail to the top of the valve cover. 41" from the rear of the head to the tip of water pump. 14" needed at rear for width of head.
The 8.3 is a half inch taller and 1.5" longer than a 466.
There's a whole slew of trans chices. Just depends on what you're looking for.
88beast
pa
sweet thanks
ya im looking at a swap and i saw a few 8.3 cummins swaps online so its possible just wanted to see what all id need to do cutting wise
nevrenufhp
torque ******
Sacramento
A few years ago I started a P-pumped DT466 swap in a Super Duty. It was going to be a pro-street diesel theme. That engine compartment was actually the biggest one in the F250/350 line up. It was going to need a 3" deep bread box from the top of the firewall, and a new section of floorboard for the tranny hump. Basically, if you approach it like a drag car, setting an engine back in the chassis, you'll be fine. Dont expect to pull off a valve cover without lifting up the cab a few inches. A body lift will help....some.
Either engine has some absolutely insane power potential. Figure your hp goals, and the torque is roughly 2.5 times that. You can pull it off, but it's no easy feat. PLAN AHEAD.
Another idea. Buy a dirt cheap beater that's like the truck you want to put it in, and hack that one up. That way, any mistakes, and re-welds get figured out fefore the real deal.
FordGuy100
Silverton, OR
I will sell you a 97 P-pumped 8.3 cummins and allsion 6 speed double overdrive tranny with about 80k miles on em for 5 grand. Rated at 325hp and nearly 1000ftlbs.
nevrenufhp
torque ******
Sacramento
That's a good deal. The Allison, if it's the MD3060 that I think it is, is worth $3k by itself. VERY sought after trans for the Med Duty truck guys. In my opinion, the best auto you can get, with a mechanical engine. The down side for a pickup, is the size. It's a big ol gorilla, and really heavy. That's why I was going with an AT545 for mine. Not the ideal trans, but for my needs, it was going to do just fine.
88beast
pa
justin i may take you up on that some day but im not sure yet if i wanna do this swap
but i would appreiaciate some pics with a 12 in ruler next to the motor for scale and once i run numbers ill let you know
FordGuy100
Silverton, OR
That trans is worth that much? My parents are pulling it out of their totaled RV. I said offer $5000 for both, should it be higher?
88beast
pa
he said trans is worth 3k and i just saw youre in or so unless youll do free shipping thats too far for me
nevrenufhp
torque ******
Sacramento
Yep, they are $3-4k at wrecking yards. Private party ads, I've seen for $2-3k. The engine is worth 1500-3500, depending on the situation.
rodgera65
CAMERON
8.3
hey folks, I am putting together my new project -8.3 and a eaton 5 speed FS4205A in a 89 gmc 2500 ext cab. frame was from a safetyclean type box van. 5 and 10 lug axles like 3500HD chevys. it takes a lot of fabrication and the dog box had to be cut out and "redesigned" at best. i have shortened the frame and used a dana 80 air-ride with 3.31's out of a ford style party bus. the 8.3 came from my buddies at the scrap yard out of a pusher bluebird bus for 500- runs excellent and came with an allison mt643 that i sold for 300-so 200 in a 8.3. i know the fs4205a is puny but i may put the rto6613 or rt06610 in.
rodgera65
CAMERON
8.3
maybe this will work- i dont usually have success adding pix for some reason.
rodgera65
CAMERON
8.3
This was a MAJOR UNDERTAKING at the least. I didn't mean to steal your post or anything, just wanted to give some input on the swap. I have put 371 detroits in 55 f350 fords with 10 speed and than a 13 speed roadranger and than a 7 speed,350 chevys in about 20 different cars,trucks,golf-carts,etc. A deutz 6 in a 3500 chevy, a 800 HP compound turbo 5.9 cummins in a 86 chevy crew cab-That WAS BAD-A$$-, a few 4bt's in different goodies like the 69 blazer that was just sold on feebay,a v4 wisconsin in a homemade motorcycle with a saginaw 4 speed, a 6.2 diesel in the 65 f100-nice truck i drove for 9 years, a 429 in a 66 f150, and so many more that are long gone. just trying to say that it is a lot of work but sometimes it is worth the effort. Just jump in there and get it done...
Nanohawk
