Kevin 007
Full-floater
1999 7.3 Superduty ZF6, when coasting in gear, no throttle for any length of time, then the clutch is depressed and engine is allowed to return to idle; the idle will keep dropping below 500rpm then catches itself just before it stalls and then settles and a nice steady smooth idle. It does this hot or cold. IPR duty cycle at hot idle is as low a 6% and never exceeds low 30's at WOT. ICP readings hover around 500 at idle and about high 2000's at WOT. Fuel pressure regulator replaced with one from dieselorings with a 61-65psi spring. Fuel filter changed, CPS and ICP sensors changes. EBPV replaced but sensor might be bad, still throwing an EBP code. Or could that EBPV be stuck? Tried replacing the IPR, got the new one on with nut on good and snug, truck ran like crap and didn't clear up after about 20 mins of run time. Both at idle and throttle. Put old one back in and instantly ran good again.
I have not yet checked my ACTUAL fuel pressure readings. And running 5W-40 Rotella t6. Any thoughts as to whats causing it to want to stall? Runs great otherwise aside from it being slow to start. Cranking speed is up but it does take longer for the engine to actually catch, both hot and cold; opposed to others. No oil in filter housing and IPR duty cycle doesn't go past mid 30's when cranking which makes me think the injector orings might be ok?
