7.3 oil pump change
david63
I have a 2000 Ford 550 wrecker (7.3). I need to change the oil pump in the oil pan. Can I just drop the oil pan to get the clearance or do I have to loosen the motor mounts and jack the motor up to get the clearance?
Thanks,
David
Double-S-Diesel
parts seller
derry pa
neither
the oil pump is behind the dampner
its in a housing with 4 bolt holding it on.
just finished one.
tonkadoctor
none ya bidnes
Here's some pics of the front cover where it sits and the oil pump so you know what you are looking for. Took these when I did mine. Oil pump isn't a bad job on these. Timing cover is a different story, if you need to replace it like I did you have to pull the engine.
Only special tool you need is a harmonic balancer puller..I used a $10 Harbor Freight Cheapo but you can get free rentals at Autozone etc too
Good luck
jorge140
