IHDiesel445
Does anyone know of a manufacturer who can supply otherwise stock pistons with a reduced compression height? I want to have them about 0.060 shorter to give about a 16:1 ratio. I'm looking for reasonably priced (as in not $250 a slug custom pistons) factory type pistons with the pin hole in a different place.
Yes, I am aware of the starting problems that may cause, but I'm looking to run a lot of boost on a rather large single turbo. Something like a 75-78mm S-400. I will also be taking appropriate measures to keep the other internals where they belong (head studs, fire rings, block filler, water injection, and possibly a main bearing girdle).
Also, does the highly acclaimed "Moose Pump" supply enough fuel to make 500-600hp?
As you can probably gather, I'm looking to build a streetable (relatively speaking) truck puller.
Thank you for any input!
Eric
Eric
