I have 5k miles on rebuilt injectors and a baby moose pump. This morning it started rough but smoothed out after a bit. After warming up it runs fine at idle. Around 1500rpm it starts to shudder a little bit. It's from the engine...it does it when not moving. Can anybody confirm an injector issue? When at 1500 rpm, there is a puff of white smoke when it slightly misses.
I'm going to run some atf to see if it improves.
Right now I'm 1200 miles from home so a little concerned. How long is it OK to run on a bad injector?
