7.3 idk top dead center of a cylinder.
Joshsarah14
Is there like a good way u guys have found to find Tdc of a cylinder . ? Since these motors have pre combustion chambers the screw driver etc trick doesn’t work . I can find the compression stroke but is there a way to truly tell if piston is at top dead center of that cylinder
Your rocker arms will be slightly loose at TDC.
Line up the mark on the balancer with the mark on the timing indicator and that should have you at TDC on either #1 or #4.
Oiler
