travisjulian
- Joined
- Mar 23, 2014
- Posts
- 173
- Reaction score
- 1
Ok. Bought new tps for tye truck. Check wiring and plug perfect condition no issues. Install new tps. Checked the range and it was at .800 v at idle. So I lossend bolts turned and hoghest it went was .869. So I took of and tur ed to where it would ve able to twist higher. Then put on check reading. Maxed out. Checked new tps tye range was correct. Went from .2 to 5 v. Is it possible that the throttle piece it goes over could have shifted and that would be why I can set it right. It is the only thing that makes sense. I adjusted idle to proper spec. Idles great but reading dropped at idle to .400. Only thing that hold me from adjusing it is a set screw and atorque ring. Im a diesel mechanic work on semi's 50 hrs a week. This truck has done nothing but challenge me from day 1. Some input would be great.
Sent from my SAMSUNG-SM-N900A using Tapatalk
