7.3 IDI power specs
bird hunter
Maine
Anybody know why the earlier 7.3 made 338 f/lb torque and the later one made 360 f/lb?? I can't remember what year the specs changed, but I was curious as to what changes made the later 7.3 slightly more powerful.
Thanks all
93f250idi
strokin
cadiz ky
Maybe the turbo'd idi's made that much? Only change in the 87-91 7.3 and The 92-94 that I know of where the injection pumps having a torque screw.
grog85
novi,mi
I believe the 84-87 6.9 made 338 ft/lb, and the 7.3 made 345 ft/lb to start with. Maybe in 92 they were upgraded to 360, but i,m not sure.
93f250idi
strokin
cadiz ky
According to forgotten diesels .com all 7.3 n/a from 88-94 have 360 tq and the turbo'd 7.3 idi had 388 tq.
dyoung14
Is getting worn out
spencer,tn
A model low compression 6.9 83 models had 315 ftlbs and 170hp:puke:
B model when they upped the compression it made 175 hp and 338FTLBS
The 7.3 from 88-91 made 180 hp and 345FTLBS
then the 92-94 NON TURBO engines made 185HP and 360 FTLBS
Finally the 93 and 94 turbo idi made 190HP and 388FTLBS
The 94 powerstroke makes 210HP and 425FTLBS
I personally own an engine from each era and my 83 model 6.9 has more power than the powerstoke i do have a 93 model idi turbo kit on it, but it will eat the powerstokr even when the powerstoke is running perfect and not missing like it does sometimes,
I can tell you there is not alot of difference between the engines and how the run power wise, and that with enough fuel and timing tweaks an 83 A model can out run a stock powerstoke cause mine out ran our psd with ease when mine was still non turbo, sounds likr the psd has the advertised horsepower right?LOL
idipwr
Ohio
Where do you all get the turbo models make 388ftlb, my original literature says 395ftlb.
hesutton
The Anti-Anderson
Bowling Green, KY
All numbers are at the crank:
6.9:
Max HP 175 @ 3300 RPM
Max torque 318 ft/lb @ 1800 RPM
7.3:
Max HP 185 @ 3300 RPM
Max torque 338 ft/lb @ 1800 RPM
7.3 IDI Turbo:
Max HP 190
Max torque 360ft
Heath
dyoung14
Is getting worn out
spencer,tn
6.9:
7.3:
7.3 IDI Turbo:
Max HP 190
Max torque 360ft
Heath
Heath not trying to argue but your numbers are not spot on,
720Diesel
