7.3 IDI Knock
southpole560
Camp Pendleton, CA
you damn jarhead (with all due respect intended from a veteran)
open the hood.
inspect exhaust manifold carefully for soot.
around exhaust ports.
all around exhaust manifold.
if you are 100% in your mind that its not an injector.
i suspect either an exhaust leak, which is my drunk unprofessional opinion.
or a collapsed lifter.
a rod knock or a wrist pin will have a lower frequency sound.
definitely AFTER the short block issue.
your lower end sounds ok.
if it is a valve, or a spring, take care of it ASAP, and dont drive it.
the slugs can take a beating to a certain extent.
but do not royally F it up.
do i need to break out the UCMJ on that ass?
There's no way it can be a lifter. I just replaced those and the pushrods. It has the same exact knock to it that the old ones had. I have looked around the exhaust manifolds and have only seen a little bit of caked oil from when the valve cover seals were leaking. But I replaced those since then. I will inspect it again for cracks. Also, I have no idea how many miles those injectors have on them. They definitely do not look like the factory ones. They have "ZP301" engraved on the side of them. I will take a video sometime of it under the hood. Before I cleaned the motor off, my friend told me that it looked like pep boys threw up all over it because there was a lot of caked oil. Mostly from slight gasket leaks and a small power steering pump leak. I thought that was pretty funny when he told me that. And no disrespect taken at all! Hear it from my buddies back home all the time haha.
another video with the hood open, request chit admitted to the chain of command.
bobs_idi
United States
Try running some additives through your fuel. (ATF, diesel kleen, 2-stroke oil), whatever you're comfortable with.
If not injectors, I'd say a valve or spring.
Good luck Marine.
southpole560
Camp Pendleton, CA
I've ran a bunch of lucas through it and a bottle of diesel klean before. Both at different times lol. They seem to make no difference :( I will take a look at the springs again. They seemed to be fine last time I looked at them though. I'm pretty sure the sound is coming either from or very close to the #5 cylinder. And I wish they would take a look at my leave request sooner! lol
crash-harris
Breaker! Breaker!
Chillicothe, OH
open the hood.
+1 and sober, lol.
FarmerFrank
Blairsville, Pa
Ok I didn't read through the whole thing so my bad if is been said.
I had a 7.3 that had a "tap" with 220k on it. I did the same, injectors, checked rockers, timed it and it would quite down when #3 was cracked. Also after a fresh oil change and 2 quarts of Lucas it would really quite down for maybe 500 miles. I figured it was a wrist pin.
I finally said screw it, I'm riding this pony till it dies. After 10k miles it still ticked and I parked the truck for other reasons. Ended up selling the heads and found a surprise, a cracked piston. So what what ones hearing might have been piston slap and a wrist pin knock.
Take it for what it's worth. I had a replacement engine and didn't care of this one windowed a block.
southpole560
Camp Pendleton, CA
I've been starting to wonder if it's a cracked piston. Maybe even a slapping piston but it sounds like it's at half the speed the tach says. If this is the scenario, what should I do? Most new diesels are expensive and require smog. I've heard really good things about the 7.3 IDI but it would probably cost a lot for another engine or a rebuild. I would do it myself but I just don't have the time or the tools with me here :/
Greg5OH
MI
you suuure its not an exhaust leak? does it get louder under load? If yes-exhaust leak
i dont THINk its a bad injector as those seem to knock more than tick/hiss.
Could be a bad valve, but most of the time its something really simple and the engine is just fine structurally.
Dont panic yet.
So many times in my foxbody I though ok yup, there goes my rod bearing, or ok bad lifter...it was jsut an exhaust leak..again, just different spot.
does your base have an auto pool? i know point magu does.
hueneme does, yours should!
you can find deals on IDI's just gotta keep an eye out.
ive bought 3, an N/A for 300
an entire truck for 500
and a 94 turbo complete for 600.
maybe theres one in the CESE yard...lol
southpole560
Camp Pendleton, CA
Dont panic yet.
I'm not sure if it's an exhaust leak. How would I check for those? Just look for cracks in the manifold? And the noise stays exactly the same, possibly even quieter on higher revs. It just goes faster. Also if I put the throttle on can hear the knock like in the video. If I'm going and then all of a sudden release the throttle, the knock gets very quiet. You can still hear it fails tly but it's just barely there. Once I put the throttle back on, you can hear the knock again.
southpole560
Camp Pendleton, CA
A pov auto pool on base? Never heard of it lol. There are a few wrecking yards about an hour away from pendleton and also a few by 29 palms. I've only been to one near 29 palms since I'm here for a shop rotation. Saw a few IDI's but I didn't know the engine status and they looked like they had been sitting for awhile.
freebird01
Post Turtle!
Fort Wayne, IN
this sounds dumb but have you checked your rocker arm bolts?
it sounds exactly like mine right after i put the motor together and had a loose rocker arm bolt...
tke395
