7.3 idi 93 to 89 swap?
SethB
Kansas
Will a 7.3 motor out of a 92 or 93 year, bolt up to a 89 with an e4OD transmission?
Just want to cross my T's and dot my I's before i buy this motor.
Randy Bush
Great Falls, Mt
You have to change your drive belts though, pulleys and such unless you are upgrading to serpentine belt. 93 will be serpentine.
SumKindaRanch
Michigan
I am putting a 1994 engine in my 1990 right now, it will bolt in just fine, but there are some wiring harness differences and the return line to the tank is a few inches closer to the passenger side of the truck. If you swap over accessories them the harnesses will match up perfectly. Remember to at least pull your radiator. That is expensive if it breaks
JU57US
