7.3 clutch
acleary555
Virginia Beach, VA
The clutch is slipping on my 1992 Ford F350 7.3 I.D.I. with Turbo. The thing is I can find a new clutch for a 92 7.3 NON turbo or a clutch for a 93 powerstroke WITH turbo. Whats the difference and what do I need? Why does nothing list parts for a 92 with turbo? It appears to be a factory Banks kit...
Iowa 73
FNM
IA
There is no factory Banks kit, no 93 Powerstroke, and no '92 factory turbo.
acleary555
Virginia Beach, VA
Guess it was dealer installed then because the Banks Sidewinder turbo and the badge on the side right under "F-350" badge that says "BANKS" came on the truck new from the dealer. What is the difference in clutches between the 7.3 turbo or non turbo I.D.I. engines is my point.
gatorman21218
Ashland VA
doesnt matter.
However I would seriously consider getting a single mass flywheel if you do not already have one.
dmaxjoe
Mount Morris, Michigan
You should have the non-turbo clutch and flywheel. The 94 factory idi turbo engines used a different flywheel. I would switch to a single mass flywheel.
Cv axle
