crabbypaul
I am taking the T19 transmission out of my 86 extended cab 4X4 and replacing it with ZF. I got a LUK LFW127 flywheel and 07-131 clutch kit, in the clutch kit there is a technical bulletin that states that the factory backing plate, located between the crank bolts and the flywheel, must be reused. I don't have a plate that is on either side of my flywheel should the flywheel be bolted to the crankshaft flange with the new bolts that came with or do i need to get a plate. I am also wondering if the same floor plate can be used with the ZF that was in there with the T19. Thank You for any help or advise
