I just read the tech on how to time the IDI with the ferrett intstruments and the digital timing light, it looks like when the light is firing the rpm is 660 and you can adjust the injection pump rotation to achieve the mark on the balancer lining up when it fires so 0 degrees at this point. After that assumption I get confused, then you dial up 8.5 degrees and go to 2080 rpm with the light, then what if the light is not firing at the mark on the balancer, and you again adjust/rotate the injection pump to make it line up, does this mess up your first setting of adjusting the pump at 660 rpm ?
Also, are the correct timing specifications for say a non-aspirated 6.9 which is used in light duty on the highway, versus a hypermax 6.9 which pulls a 6,000 pound trailer the same?
I haven't studied the postings here in a while, so if this has already been covered sorry about that.
Thanks for any advice here, correct timing for best fuel economy would be nice but if other specifications are better for the engine, that's what I would want.
