I have an 86 6.9 (with about 130,000 miles) that had a severe starting problem when I bought it last summer and the problem got much worse as the weather got colder.
Here's what I did:
Replaced all return lines using a nice kit...the lines were dry but cracked so now they are good...did that last fall.
I also replaced the glow plugs.
Problem continued and didn't seem to change...it seemed much worse when facing uphill.
So I went ahead and removed the mechanical lift pump replaced with an electronic one...followed the instructions on this site which saved me...thank you.
Seemed to fix the problem...for about a week.
After the car sits (when facing uphill) the car starts perfect and then stalls after about 10 seconds sometimes.
I don't have to wear out the starter now though which is good...I just bleed the shrader valve on the fuel filter with the ignition key turned so that the fuel pump is running.
I see air in the beginning when I do this if I am trouble starting. After bleeding I can start in less than 10 seconds. It also runs a little rough while warming up sometimes but runs perfect when hot almost all the time...very little starting problems if truck faces downhill or on level ground I believe now.
Here was my plan but I am not sure if its an efficient one:
I was going to buy a Chilton book first and then trace the fuel lines to the tank, maybe replace the line if its not too hard...its probably original...I haven't messed with the injectors or IP but they seem dry and truck runs perfect after it warms up...I was maybe thinking that the fuel selector valve (I have to figure out where that is) or ditch the water separator (install a separator/fuel filter combo and ditch the original water separator).
Any help that can save me time and money will be much appreciated since I have neither in my life right now...What is the most likely thing that could be letting air intrude?
Thank you always for the time and help
Here's what I did:
