trapper
Boom Boom
Well ive decided to rebuild my spare 6.9
currently i am breaking down the block to take to the machine shop
i will have it hot tanked magnaflux and Pressure checking
then i will aline hone the main bores and camshaft tunnel
followed by decking the block
the heads will be checked and rebuilt along with some port and polishing
new push rods ,valves, and lifters along with 7.3 rockers
i will be getting a new set of pistons looking for the low compression pistons, which will be ceramic coated
Ive been looking into hypermax rings, main bearings and rod bearings and pins
set of head studs and coated gaskets along with a turbo
Would you boar the engine 20 over ? or leave it alone ?
