boostedretard
Hello. First post here actually. I am currently shopping for a good running 6.9 rig. I am to rip the chassis of its cab for my C30. After that I would like to eventually take the 6.9 bolt it to a ZF5 and stuff it in a car I have. From the research I found. It seemed that the 86-87 blocks were best and the head bolts and head gaskets were weaker points. I dont want the 7.3 due to the cavitation issues. I would like to pull roughly 200hp and 400ft lbs from the 6.9 if at all possible with the stock pump and without tearing into the engine. Are head studs a must with a turbo on a 6.9? I would likely be building a custom turbo setup as I am not entirely new to idi diesels as I built the low low budget twin setup for my old 6.2 below...
