Hi, I look at these pages all the time but don't know how to use them... I hope you all can help. I have low oil pressure, about 5lbs idling and maybe 25 lbs max. I figured it was probably the factory guage so I installed a mechanical guage, same thing. I replaced a fitting on the oil line that feeds the hypermax turbo with a 'T' and that's where I get my pressure reading from. The oil pan is dented right at the plug and after looking at another 6.9 I have I realized that the pick-up tube has definiaqtely been affected by that dent. I am not sure that bending the tube would cause the low pressure or not and want to explore any other ideas before I lift the engine out to check that. Any ideas?
