Hello, All,
We have been progressing on a late 86 6.9 swap into a 79 f-150 4x4. Most things are fairly straight forward, but having sources like you all to answer some questions has helped take out some of the guess work.
Though we have had the truck running several times, it starts somewhat hard, and smokes a lot. Maybe some of that is because the swap was started a year ago (or more) by the previous owner, and it needs to be run and driven (not drivable, yet). Unfortunately, we have had to resort to ether (a very short shot, after GPs have cooled) to start, as a manual 10 second hit with the NEW Motorcraft glow plugs just doesn't seem to do it. I have read a lot about the return line issues, and want to be sure we are good with our fuel system. We have a fresh (compatible metal) tank, with a 3/8" line connected from the pickup to the lift pump. For the return, we have a 1/4" line running DIRECTLY into the tank. Is there supposed to be any restriction or check valve in the return line? We connected it to the grommeted opening in the top of the gasser's tank, using the "vent valve" that was attached, but removed the valve from it, so there is no restriction on the return. We just were not sure, as it seems to be so important that there are no return line leaks at the injectors.
Thanks for your input!
