6.0 needs more power
matt
Paso Robles,ca
i have 2004 ford f250 4x4 ext cab. i have AEM intake, 3.5" down pipe to cat to 4'' to 5" out pipe. and i have the edge evolution. what can i do to get more power out of my 2004 6.o that might be easy.
get rid of cat put arp muffler in
injectors
power elbow
zpd307
Zumbrota, MN
all things are relative...... when i had my 03, i wanted more power, now with my 90, i wish i could have the power of my 03. without studs, you are borrowed time anyways.....
JohnBoyToo
DFW, Tx
Take this in the manner it is offered... trying to be helpful...
1st get rid of the Edge....
have heard of TOO many with tranny issues as a result of using them....
Get a sct programmed from someone like Innovative Diesel..
my ex has done 8.9 in the 1/8th, which is more than fast enough for a Family bus :)
anything more than that will require studs, injectors, turbo, water/**** injection... etc...
stonecrusher
ohio
stack the edge with an sct programmer and you will be able to control everything and be able to use every bit of the power
Bo17
