kblackav8or
I was wondering if anyone has looked into swapping a 3126 into a Superduty? Seems to be about the same size as a 5.9. That has been done already so will the Cat fit? Spec sheet lists it at about 43 inches long and 38 tall. It doesn't appear to be as big as a DT-466. It is also lighter at 1200 lbs or so. I figure that with some creative weight savings, the truck could/should handle about the same after the swap. Do that and re-gear to 3.50 ish with stock sized tires and you should be able to move/tow anything you can hitch to the truck. So far what I read is the 3126 is less troublesome then the 5.9 in heavier apps.
Kevin
Kevin
