2wd leveling kit
RyanDamo
1 IDI 2 Strokes
Shelton CT
Hey guys, i have a 97 f250 crew cab short bed powerstroke thats 2wd. I was wondering who makes a leveling kit for the 2wd trucks. I cant seem to find any anywhere
MUDKICKR
NITRO WV 25143
if its a coil spring frt end the easiest thing to do is lower the spring buckets. cut out the rivets and drill new holes 2" lower
A leveling kit is an unleveling kit once you put a load in it. :dunno If you really want to be level all the time, switch to an airbag suspension or at least get the Firestone Ride-Rites as helper springs.
RyanDamo
1 IDI 2 Strokes
Shelton CT
i am getting air springs for the rear, is there kits available to raise the nose? i dont think i can squeeze airbags in the front.
93f250idi
strokin
cadiz ky
eBay has one for f150s don't know about f250s. I almost bought one for my f150 but decided to leave it stock
93f250idi
strokin
cadiz ky
If the f150s and f250s coil springs are the same then I don't see why it wouldn't unless they can't hold the weight.
RyanDamo
1 IDI 2 Strokes
Shelton CT
thats what i figured, i just wanna see if anyone has ideas before i purchase things
Diesel_brad
Dunce
gilbert pa
Coil spring spacers are coil spring spacers. All you need is the correct diameter. Or you can go with a pair of F350 coils
