2001 Excursion should I buy?
I would do it in a heartbeat at that price, if he can show paperwork for the trans.
Otherwise I would drop him down $1k.
Appears to already have a ts6 style chip.
If the ebpv hasn't been deleted, you can get tunes that'll turtn it into a exhaust brake.
F350camper
BOOST!
USA
Crawl underneath and look for rust on the inner rockers. Also the dog legs of the rear ( side ) doors, you should be able to check for rust by slightly pulling up the weather striping in the lower rear corners.
Thatoneguy
Boerne, Texas
I would second the rust comment. If it doesn't have any serious rust, runs good, and all the normal checks like fluids, blowby, etc... Check out good I would jump on it. And rust spots you do find I would take a small screwdriver and poke around on. Surface rust can easily be taken care of with POR15 or any other effective method of your choice. But big rust is bad.
Sent from my VS980 4G using Tapatalk
MTKirk
Billings, MT
I went and took a look at the excursion and decided to pass, if anyone else is interested go for it!
jwalterus
Made in America
Air Force
Garrison, ND
I went to get his number off the ad the same evening MTKirk posted he passed on it, ad was down.
tke395
