1994 rear idi sending unit question
redtop_travis
East Greenville, PA
I found the screen from the bottom but the side is missing somthing. Looks like somthing should be pressed in the round opening on the side or its gonna suck air before the tank is empty. Anyone know what goes in there? I dont see it in the tank.
You must be talking about the fuel tank suction shower head. ,If so just remove that head and install a piece of fuel rated rubber hose and a clamp. Its 3/8 tubing. Cut a V in the bottom of the hose so it wont suck tight to the bottom of the tank. Use the suction shower head length to determine how long a piece of hose is needed.
redtop_travis
East Greenville, PA
Ok thanks. I just need to find out what type of hose will hold up to Fuel. Just in case I ever run veggie oil I want to be sure eveything is set up for that.
Do a google search for "viton hose". Viton will stand up to any fuel you can run.
If your not comfortable with hose just use some metal tubing and a connecter.
