Hi everyone!!
I have a problem I just can't sort out. We have a 1993 F350 brush truck with a 7.3L IDI. The rear tank fuel gauge doesn't work, and on a wild land fire truck, you can imagine this just isn't handy. I have checked wiring and grounds thoroughly. So I snatched a sending unit out of an identical truck that is out of service. Thought I would plug it in and see what happened before dropping the tank. Well it worked. Moved the lever up and down and the gauge followed. Problem solved right? Dropped the tank, put the sender in, no gauge. I'm at a loss fellas. Any help is greatly appreciated.
