1992 E-350 wiring harness?
Andertusa
S.W. Minnesota
I just recently bought a 1992 Ford E-350 Club Wagon with a 351w and I'm interested in swapping in a 'headlight relay' kit like is smart to do on the F-series of the era. Does anyone know which one of the body styles would have similar wiring harnesses to the van's? Or does anyone know of a kit for these van's?
Sent from my E6810 using Tapatalk
Administrator Moderator
My best guess on a "like kit" would be:
92 Up E-Series, I would use a harness for a 92+ OBS F-Series
91 Down E-Series, I would use a harness for an 80-86 Bullnose F-Series.
My reasoning, the 92+ body style van is similar in design, (and was more than likely being designed at the same time) as the 92+ OBS pickups. The 91 and Earlier F-Series was designed in the late 60's/early 70's and was released in 1974. They still used the "older design" components through 91, such as using glass, sealed beam headlights, and the round glass fuses in the fuse box. Ford used the same basic design on the E-Series, from 74-91 with only minor changes over the years. This is one reason vans still used the same instrument cluster through 91 that was in the 73-79 F-Series.
We have owned a 73, 83, 88, 89 and 92 F-Series truck, and an 85 and 94 E-Series van, and you can see the design similarities between the different years, and where the van gets it's designs from.
Andertusa
S.W. Minnesota
That's kinda what I was thinking as I was thumbing through the LMC truck catalog for my 95 F-150 Supercab long box 4x4. What kinda was 'worrisome' was the idea that a kit designed for the 95 truck might have a different wiring color-coding, so plugging it in might have undesirable consequences [emoji849]
tke395
