1992 drivetrain in a superduty
Kodeman
Esparto,Ca,USA
i have a 1999 powerstroke 4x4 with a auto, I also have a 1992 7.3 idi 5 speed 4x4. The auto trans just went out again. My question is , can i put the 5 speed from the 1992 in the 1999? will it all bolt up ? Didnt know if it might be a different bellhousing pattern or input shaft etc. Thanks, Kodi
Double-S-Diesel
parts seller
derry pa
the trans will bolt up, need a clutch and flywheel from a 94-97, will have to use a combination of hydraulics, master from a 6 speed, and slave from a 5 speed.
clutch pedal is stand alone on the sd will need the 92 t case and then the driveshaft ends will be different, not shure on floor hump clearance 6 speed is different than and auto, also need a 6 speed cpu,
and some other things Im shure
