Tdvjensen
Well I have a been a member for a little while now and have been soaking up as much technical information about the older IDI's. I currently have a 1992 F250 4x4 with the 7.3/5spd combo. I picked up the truck for free, and it took a starter motor, some battery terminals and some slicing and dicing of the the clutch saftey wiring (thanks to an aftermarket command start) to get it to start off the key.
Here's my problem though. It starts quickly and strong, even down to slightly below freezing, sometimes with a little more cranking. It purs like a kitten at idle, no miss and slight smoke when cold. After its warmed up some and you rev it up to around 2000rpm, it starts to miss badly and smoke like crazy. It revs up nicely to 2000rpm, and then after that its crap.
What part should I start diagnosing first? I do not have special idi tools etc, but a lot of mechanical knowledge and am not afraid to get in there. I think I might have come up with a use for the truck but would like to understand what is wrong with it to determine if its going to work for my next project.
What I have done to it is installed an injector return line kit (since it did leak there before, and unfortunately still does so I think I might have messed up some O rings etc). Other than that a starter motor and a some battery terminals. Any thoughts would be much appreciated.
Tyler
Tyler
