1991 f350 crew cab dually banks turbo 7.3
Richard Clasby
Redlands CA
I purchased this great truck from the original owner's wife several months ago with the intent to keep it for a long time. Now I need to sell it due to losing my storage spot. The Owner was a Diesel Mechanic who worked on Diesel Emissions systems for Big Rigs so he knew his stuff. It's never been smoked in and he babied it and changed the oil every 3000 miles. I even have the original "build sheet. He always made certain to keep CSA in the cooling system. I keep CSA in it as well. I paid 5K and just put 3K+ into it to get it running great. It only has 90,000 original miles on it and that's verified with Car-fax and through the California DMV Registration. There is no play in the steering and it tracks straight and true down the road. The Ford (AOD) Automatic Over Drive transmission shifts perfectly. It downshifts when needed does it's job by finding and staying in the correct gear. I added sound deadening to the doors and now it's quiet similar to a more modern diesel. It's easy to talk on the phone or listen to the radio. No diesel drone.
The interior is a 9 out of 10. As you can see from the pictures; the seats, doors, carpet, door panels, headliner and dash are all in excellent condition. The seats (no tears) and carpet have always been covered. There are no cracks in the dash or doors or anywhere. Everything works except the fuel gauge for the front fuel tank. Both fuel tanks work fine, but just the rear tank registers fuel. I use the front tank for about 150 miles then switch to the rear. I am told this is a $200 fix but I forgot to get it done the last time I had it in with my mechanic (Dynamic Diesel, Yucaipa CA).
Everything else works: Tachometer, Speedometer, Temp Gauge, Battery Charging Gauge, Oil Pressure Gauge, Cruise Control, Horn, Windows, Blinkers, High and Low Beam Lights, Automatic Door Locks, Interior Dome Light, Dash Lights, Running Lights, Wipers and Washer, Radio, Turbo Boost Guage, Exhaust Temp Gauge, Air Conditioning (from all vents), Heater (from all vents) and anything else that is on it.
New Tires (four are new two have 80% tread)
New Fuel Injectors
New Glow Plugs
New Glow Plug Controller (it works) It starts right up every time.
New Fuel Return Lines
New Thermometer
New Air Conditioning Compressor
New Air Conditioning Accumulator/Drier
New Hoses
New Belts
Oil Just Changed
Transmission Fluid Just Changed
Front End and All Lubible Parts Lubed
Brakes Checked and Adusted
Suspension and Spring and Shocks Checked
Cleaned and Oiled the Air Filter (it's a K&N with a Banks Logo)
XLT Package includes:
Tilt Steering Wheel (has been covered so it is in good condition)
Electric Windows
Electric Door Locks
Cruise Control
Premium Sound System
Air Conditioning
Sliding Rear Window and the lock is not broken
Front Disk Brakes
Anti-Lock Braking System (ABS)
I have all paperwork.
The following was installed by the Dealer in 1991:
Banks Turbo
Banks Turbo Boost Guage
Banks Exhaust Temperature Gauge
Banks Trans-Command Automatic Transmission Managment (for sharper shifts)
It also has a Draw-Tite Trailer Brake System. The light comes on when I move the lever but I have never used it.
The GEM Top is made of Metal I think
it's steel. It's very sturdy and has a rubber seal to the back window.
Richard Clasby
Redlands CA
More pictures. 7k takes it.
Richard Clasby
Redlands CA
More pics
Richard Clasby
Redlands CA
Per your suggestion...more pics
Richard Clasby
Redlands CA
Some more recent pictures. I"m driving it so the mileage is increasing. This is an awesome truck! I'll take $5,999. I wish someone gave me a truck like this for 5,999. I out in the boonies so it's kind of hard to show it. If it doesn't sell soon I'll give it to the autobrokers. Thanks.
Richard Clasby
Redlands CA
Ha ha. I tried to upload the pictures and it said that they did not go through and of course the did...twice!
Richard Clasby
Redlands CA
More pics
Lance
