riphip
Don't get snakebit out there in the weeds
It can't be off of a Chevy. Even if a GM one would bolt up (I'm not sure that they would physically interchange), the injector line fittings are bigger on both ends of the GM lines than on ours. That's going out on a limb and assuming that the 5.7 uses the same style of lines as the 6.2/6.5. Also the flange that actually fits against the gear housing is triangle shaped on the GM pumps while it's round on ours. You can't confuse the two. I'm thinking that with the return line off of the top of the injector pump, then some fuel would come out of the lines on the injectors "backwards" towards the injector pump while cranking the engine over. When all of the return lines are attached, it's a closed system. The excess fuel that comes out of the injector pump would make the fuel go in only one direction, away from the engine toward the fuel tank. When the system isn't closed, the fuel could go in "all" directions. Another example would be a round of ammunition and a gun. If the round is exploded out in the open, then the force of the explosion will go in all directions. If fired inside the gun like it was designed to be, the force of the explosion will only go out the end of the barrel. There's A LOT of difference in pressures here, but it's the best way that I can describe it.Might be a dumb question, but could it be off a Chevy and not for a idi? I thought I read on here that they run the opposite direction. Am I off in the weeds here?
