Devon Harley
If you swap to a 12v is there a way to run your idi a/c system?
What if my ac is a V belt system?
I done been there and done that.
V-belt A/C compressor is super easy.
Unless you cut a huge notch in the engine cross-member, it is not possible to use the Cummins/Sanden compressor in the Cummins location.
I sandwiched a big B-groove V-belt pulley in front of the Cummins fan-pulley.
I just went to the local lawn-mower repair guy and dug through a barrel of junk pulleys until I found one of sufficient diameter to lap closely over the serpentine pulley and have about 1/8" clearance between the two belts.
A machinist friend precision-drilled the six holes for the mounting screws, so it would run true and not "lope".
I very-much prefer the two-belt/V-belt system over a single serpentine system.
I can remove the V-belt without dis-abling the serpentine system.
I can add any number of V-belt accessories simply by building brackets.
In my honest opinion, a V-belt system beats even an 8-rib serpentine system.
The V-belts are less apt to slip and it is ever so much easier to add or remove accessories.
I have my original 1985 Ford compressor in pretty-much the original location via a homemade bracket.
I didn't even evacuate the system; I just layed the compressor over the wheel-well while the swap was done and didn't lose a speck of refrigerant.
Is there a way to externally tell the difference between a 709 and a 508?A lot of compressors have the same capacity or more, but the 709 has 7 cylinders, to divide it up and smooth things out, makes a world of difference ( 709 = 7 cylinders, 9 cubic inches , the older 508 was 5 cylinders , 8 cubic inches, darn near the same capacity and same footprint, but not as smooth or efficient , the 709 was made to supercede it in any application)
