10.25" Sterling question
Knuckledragger
Payson, AZ
Are the pinions cut with different length splines, or do only the yokes have longer splines? Trying to find out if I need to only replace a yoke or the gearset as well. Thanks!
Macrobb
North Idaho
To go from a short-spline to long-spline setup(I'm guessing?) yes, the spline length on the gearset is longer.
Philip1
Northeastern Nevada
I'm pretty sure the splines on the pinion shaft is longer to accommodate the longer yolk
Sent from my SM-G975U using Tapatalk
austin92
Brazil. IN
You can put a short spline yoke on a long spline pinion. That’s how it’s set up in my truck after I regeared. I also used a ratech crush sleeve eliminator
Philip1
Northeastern Nevada
Physically it is possible however it will not be good for the axle. The yolk isn't long enough to keep preload on the bearing and will eventually cause the pinion to fall into the pumpkin damaging everything in the internals. This is why I had to rebuild the 10.25 in my jeep
