01 Yamaha Blaster...modified...fast...for sale
holtzer1
missouri
i bought this quad in 01 brand new off the showroom floor, it has been stored inside its entire life, never even left outside overnight. very well maintained..oil changed every other ride using bel-ray 80w wet clutch gear oil. 32:1 premix using Maxima/93 octane.
runs with 400ex's all day long, leaves warriors sitting right off the line.
mods list
modifications/upgrades
maxxis razr rear tires 50% tread remaining
aluminum rims
hydraulic brake conversion(front brakes)
banshee spindles and hubs (front)
banshee axle ( 4" wider than stock blaster)
burgard 2 wide/ 1 forward chrome a-arms(total of 4" width, 2 rides since installed)
high flex heim joints (ball joints..only better)
banshee rear hubs and rims
3.75" extended swingarm
400ex rear shock (compression/rebound adjustable) (spring rate to match extended swingarm)
maier race cut front silver plastics and tank cover (4 rides since installed new)
custom painted metallic blue frame and steering stem
custom painted metallic blue swingarm
alba pro elite front bumper
lrd pipe and silencer
k&n filter
k&n outerwears filter lid
shockwears yamaha shock covers
14tooth susnstar front sprocket
38tooth pbi racing aluminum rear sprocket
ported and polished cylinder
.040 wiseco pro-lite piston
milled cylinder head (145 psi compression)
vito's 4degree timing advance key
vitos oil injection blockoff (runs 32:1 ratio pre-mix-Maxima oil/93 octane gas)
vitos reed spacer
boyeson pro reeds
28mm mikuni flatslide carb
tors eliminator kit
moose racing engine seals
AC nerf bars
motion pro cables
asking 3200 OBO
well over 6-7k invested
contact me at [email protected] for any questions or offers.
located near STL Missouri
Big Bear
