working on a 01 F350 7.3 CCC SB
fighting a loss of power issue.
the ECU was throwing a injection control pressure failure,
found the ICP to be full of oil....
i changed that sensor (motorcraft), and no change.
when under throttle the ICP psi does not climb above 700 psi.
and climbs to 65%
i purchased a IPR (motorcraft) and just swapped it out.
still no change.
the IPR pigtail looked toast, so i replaced that as well.
i deadheaded the pump, and it produced 3500 psi
i have not dove into the injectors yet,
could this be a injector O ring thats blown out?
HPOP just done?
and climbs to 65%
still no change.
HPOP just done?
