Buying 99 7.3 F350 flatbed 4x4...maybe
MTKirk
Billings, MT
Having a hard time talking myself out of buying another truck, 99 7.3 F350 crew cab, flatbed, 4x4, zf 6 trans, 270K miles. New clutch and flywheel, new injectors, new brakes. Needs tires, has a crappy welded up nightmare for a bumper. Think I can get it for $7000. I would be using it to haul the my 5000lb travel trailer all over creation. What do you think? I've never owned a zf6, are they good trannies? Anybody tried any of the $200-$300 bumpers on e-bay & amazon? any comments appreciated!
Thanks!
Man if it’s clean I would get it. Zf6 is great for towing, dunno about the eBay bumpers.
greenskeeper
PA
Thanks!
Bought my 99 (CC,4x4,ZF6) a few years back for $6k with 220k miles on it and zero rust
The ZF6 is indestructible unless you loose fluid or the radiator/cooler assembly fails.
I run pennzoil synchromesh in mine (and all my standard transmissions) although it is spec'd from ford for ATF fluid.
The 7.3 PSD and ZF6 is probably the most sought after engine/transmission combination, and "they aren't making any more of them"
MTKirk
Billings, MT
Well, it followed me home. The cab is in great shape, no rust, interior is good (but filthy). Engine is strong, with about average blowby I've seen on trucks with this mileage. Transmission shifts great, clutch linkage feels like it needs a little attention. Oil cooler needs a rebuild, I'm pretty sure turbo pedestal is leaking oil & needs resealing, carrier bearing sounds like it's about to go. Given the mechanical issues I offered $6,000 and he took it. I think I did OK, but I've got a lot of work to do. Anyway, I'm a powerstroker now!
MTKirk
Billings, MT
First repair completed today, fixing parking brake. I feared the worst, but turned out to be 5 minutes under the truck with a brake adjuster spoon & done, AWESOME!
IDIBronco86
