Help....Need a New Diesel Filler Neck for the MidShip/Side Tank
OkieDieselMan
Oklahoma
Can't find a New Diesel Filler Neck for the Side (MidShip) Tank for my 1993 F250HD....Didn't think it would be a hard Part to find?? Can Find "Gas" Filler Necks (i.e., with the ~13/16" Flapper Hole), but not and " Diesel" Filler Necks (i.e., with the ~1" Flapper Hole or just an Opening)......Does anyone know of a Company Selling the "Diesel" Filler Neck...at a "reasonable" Price?
I can say that I have taken my frustrations out on a too-small filler neck hole with a chisel end on an air hammer before. It worked fine for me. Not that I'm recommending it, it's just another option.
Olds64
Edmond, OK
Do you need the rubber hose that goes between the fuel tank and filler neck? If so, this is the only place to get the right part:
If you need the filler neck that attaches to the pocket behind the fill door make sure you get an 87 or newer filler neck. They redesigned the vent for the fuel tanks in 87 to prevent the fuel pump from always clicking off.
Use this search engine to find a truck in a salvage yard near you.
BTW, I'm north of Edmond, OK. I might try to make it to the Coffee and Cars with my truck on the first Saturday of the month. It's at the Life church parking lot on 178th and Penn in OKC. I'm not sure if it's going to happen next month though because that's 7/4/26.
dogdanblue
