headhunter38
In the process of putting the front end of my truck back together after doing axle pivot, front leaf spring and shackle bushings. 1991 f250 4x4. I am having difficulty getting the axle pivot bushings to line up enough to get the bolts through. I dropped the whole front end at once and did all the bushings at the same time. The leaf spring and shackle bolts are all back in. I thought that we should do those first because of the way they arc would make it difficult to get the spring eyes in side the hangers. However after struggling with it the last two nights im thinking of taking out the leaf spring bolts and getting the axle pivots in first. Is that the preferred way to do it?
Im pretty certain that if I was doing this on a lift or higher off the ground I could get it with a pry bar. However im doing this on jackstands and can only get like a 16 inch pry bar underneath. If I ever do this job again I will definitely raise the truck higher off the ground.
Any tips or tricks are appreciated. I need to get this done by the first or else ill have to pay for another month of rent at the storage unit im doing this in.
