Brake issue after pulling engine
steelholder
Up and away
Hoping you guys can help with a brake bleed issue that I'm having. I recently pulled my engine and have put it back in. Engine is running fine, however, now the brake pedal has all the symptoms of air in the brake system, but I can't figure how that could have happened. The first time I pumped the brake., it works well but the second, third and fourth time it gets very stiff and is not responsive at all, I give it ten seconds or so and I get one good brake pump. What would you guys check here? I have no idea how to bleed the brakes in a truck like this.
ihc1470
Idaho
Sounds like you have low vacuum, might check that all the hoses got reconnected.
DirtyWood
Earth
If you have a vac gauge I would test the system and you should have 26 inches of vacuum at idle. The belt on the vac pump does not need to be overly tight either.
FrozenMerc
SW Missouri
Think about what you changed. Assuming you did not open the brake system during the engine swing, so there should be no way for air to get into the system. As Dirty and IHC alluded to, you probably did mess with the vacuum pump during the engine swing. Start there.
Is it making good vacuum?
Is there a damage to the vacuum line?
Did you hook the vacuum line up to the outlet of the vacuum pump?
steelholder
Up and away
I think you guys are right about a vac leak. I replaced one hose that was there before the engine pull but that hose leads to 2 ends that are no connected anywhere. Can you guys take a look and help with where these two ends are supposed to go? I taped both ends to see if it would help but no go. Bottom picture stems from the T fitting on first pic.
Generally those have something to do with the HVAC controls. Those plastic vacuum lines are notorious for breaking. NOT one of Ford's better ideas. Look around your heater box. You should be able to see where at least one of them attached. Why not get some small diameter fuel line and attach the two ends? The worst that will do is nothing. It just might solve your vacuum leak.
steelholder
Up and away
Thanks. Might you guys be able to check in your trucks where those two lines lead to and post a pic here?
Heymack
TX
Here are a couple shots. The short hose goes into the evaporator core housing. The long end goes into the vacuum block mounted to driver side inner fender (on my '93). The last leg goes into the HVAC wiring harness, and presumably into the cab to operate vents.
Heymack
TX
Couple more pics
DougBoy66
Cass County Missouri
You will know if it goes to the HVAC also because if they are not attached you cant change from vent to floor to defrost until they have vacuum
DougBoy66
another thing to consider, if you find that you have solved all your vacuum issues and are still having the pedal fade, I had that issue because of the RABS. If the wiring got dinged up when the engine was pulled it might malfunction. Mine just let brake fluid by the valve all the time so the pedal was always mushy.
steelholder
Up and away
I think my issue is directly related to the brake booster which I'm getting today. I will report back and let you guys know if that solved it
steelholder
Up and away
Unfortunately this did not solve my brake issue. The booster did need replacing though. The old one was pretty corroded and had an old leak. The hissing sound at the pedal stopped but the symptoms persist.
Symptom - (all within a 10 second period) 1st brake press works great, truck reacts immediately and stops, 2nd press feels much stiffer and significantly fails to stop the truck, 3rd and 4th press very stiff and little to no reaction in stopping the truck. If I let off the brake for about 15 seconds or so the cycle repeats.
steelholder
Up and away
What is the RABS?
Weirdo
