Cincinnati Guy
The girlfriend is hooking me up with the waste oil at Taco Hell. I want to run it in my truck, So how do I go about doing this. How do I filter it out? Can I mix it with my diesel or must it be ran straight?
You CAN NOT mix it with diesel, it wont stay mixed, it needs to be be in a separate tank and heated to flow like #2 diesel.
hope this helps some.
Yes it can be ran, but it needs to be filtered properly, down to about a couple of microns.
You CAN NOT mix it with diesel, it wont stay mixed, it needs to be be in a separtate tank and heated to flow like #2 diesel.
You also need to replace all natural rubber o rings and gaskets that the wvo will come in contact with because it likes to eat up rubber. Replace them with vitron orings, they sell kits on ebay. Also, dont forget, the mechanical fuel pumps have rubber in them, so an electric fuel pump that is resistant to wvo will be needed.
Ah, ok then. You see, i thought that what applied to using bio-diesel also applied to wvo. Its been a while since ive been on the forum, so forgive me you guys.
