getting real close to driving it as i got some more done this weekend
added some more supports to the pedal assembly and steerting count, no pics as nothing fancy to look at
the last of my brake lines came in so finished plumbing them up with one small twist. cause the truck has 1992 Sterling rear diff the e cables did not match up and they were all rusted up so cut them all off. so my solution to this was to put a lock off valve in the rear hydro lines. now it my not be DOT legal but i dont care as it will do the job just fine
ran ss lines inside the cab and put bulk head fittings on the firewall and floor to hook it back in to the system
still have to finish bleeding the system as i had to get one new caliper and then the rain came so was not able to get all the air out
also got the trans tunnel coated and installed and shifter boots installed
had to switch out my injection pump to as i had my turbo pump still on the motor and its a little ******* fuel and still needs a new head unit as truck wont start when hot. got a used pump that had a rebuild done not to long ago and looks in really great shape. was able to a timming light and signal adapter from one of the guys at work so timmed the truck up sounds much better now
so all that left now before driving its is blead the brakes and do something for guages, have to get the done soon as have to go and get firewood in the next week or so
