started to work on the inside of the cab as i want to make it nice to ride in. when i got the truck i pulled the carpet back and found out that there was no real floor boards on the drives side. also found a small hole on the pass side so did not think much of it, when i started to pull the carpet out as its rotten i found even more cancer. turns out my small hole was a real big hole that some one had rivited some tin over #help so i had to fix that
still have lots more repair to do but that will have to be at a later date
also had a major death wobble because the one tie rod was shot. looked into getting a new one and the best deal i could find in town was over $200. even online the best i could find was $150 so i ordered some tube inserts and made my own
used 1ton chevy tie rods and some .25 wall DOM
mounted my my shovel and jack all in the box
shovel mount is simple, just a bolt welded to a plate that goes through the shovel and then a pico clamp for the handle
and jack all mounted on the other side with some scrap tube
and the two trucks together
