Zf-5 Input Shaft Leak
94_IDIT_0830
Atlanta, GA
Hi all!
I've got the transmission out right now from my truck. I just bought the truck and its been leaking transmission fluid and ruined the clutch. After I got the transmission down I'm confused and would like to have clarification before taking the transmission apart. I have a zf-5 s5-42 with a press-in style pilot bearing quill. It seems that the seal currently in the transmission is around the quill. The leak is coming from between the input shaft and the quill. Is there a seal for in there? I cant seem to find anything. If not, what would cause this leak?
Thanks
94_IDIT_0830
Atlanta, GA
It's in the boot on these transmissions, correct? The boot seems to be clean and free of debris. It is a little torn up though.
honestly I don't even know if these things have a vent.. I know my S47 does,behind the bell housing infront of the shifter tower.
and I was quite sure my 2wd S42 did, but I went out and looked, couldn't find one, so it must be under the boot?
Macrobb
North Idaho
Judging by the oil seepage on all of my trucks, it sure looks like the gear shifter 'seal'/boot is a vent... or at least it becomes one after 25 years ;)
I thought I remembered that too Russ. You have to disassemble the transmission to replace it.
Yep. Had mine replaced when the tailhousing was changed. I believe it's pretty much a complete tear down the way the case splits. May be able to stand it up on the tail and pull the front case off but it will be extensive.
94_IDIT_0830
Atlanta, GA
Okay guys! Update! So I finally got the transmission apart to take a look at exactly what was going on. The original seal was dry and just kind of hanging out on the shaft... no press fit at all. That's my next dilema, my new seal is the same. When it sits around the shaft its a very unpromising fit. The only area that I could suppose that it would press into on the case has a massive clearance difference between its ID and the seal's OD. Am I missing something here? This leak already caused one clutch, I don't want to go through all this trouble to destroy another.
New Seal
Seal on input shaft
Shouldn't the seal have a press type fit in here?
Obvious gap between seal and input quill
DaveBen
Ukiah, Ca
I don't think there should be a seal on the lower shaft. No reason for it. The tranny case is enclosed at that seal, so nothing can get out or in. The top shaft (where the magic Blue finger is pointing) has a seal on the outside of the bearing, which is correct.
Bo17
