Diesel_brad
Dunce
see thats what ive been saying since you have first had experience i have a question.
if you can infact get an alignment with 2 inch springs if i went to 3 or 4 inch springs but moved the i beam mount hole up two inches would that infact keep it alignable ive seen alot of people that swear by it ... im going to try
but ill leave the stock springs alone and im getting springs for a 93 f350 reg cab with a 300 6 cylinder they are progressive rate load springs the only factor i dont know is how much drop they will give me i know there is a huge weight difference in the motors so we will just have to see
You are NOT going to be able to mount the pivot bracket higher. It is already jammed in there. If it was that easy, they wouldnt make new beams or spindles.
And those 6cyl springs are gonna sag the front out pretty good. Hopefully you will be able to align it
