wtb/wtt 4.10 rear for 3.73
performancelaw
Auburndale FL
I need a set of gears for the rear. I'd like to get a set of 3.73 and either buy or trade for the 4.10 I have in there now. If you don't have any but know where I can get some please let me know.
FORDF250HDXLT
Maine & Oklahoma
our diesel trucks didn't come with a 3:73 gearing option.so anyone who would happen to have a sterling for a bolt in replacement for your '94 truck,would have been geared via aftermarket ring and pinions,and likely professionally installed.so you won't find anyone willing to swap.
our stock options were 3:55 or 4.10.
to get close to 3:73's i reduced tire height with 3.55 gearing.
if you swap in a 3.55 salvage yard axle,for your 4.10's and run stock 215's on that DRW pickup,you'll be right where you want to be.:)
oh,i see your 245's.boy,with 4.10's and them tires, she pulls off the line good hey.;)
well if you keep those and just swap to a stock 3.55 axle with someone,or local yard,then you'll be good with 3.73ish gearing right there.about 3.69:1 you couldn't tell the difference.same final results.:)
performancelaw
Auburndale FL
I drove it today for the first time since swapping from the e4od to the zf5. In over drive I'm turning some rpms that I don't like. At 50 mph I'm turning almost 2,000 rpms. Maybe its normal but I don't know.
Fordman84
Fordman84
Vesper, WI
to bad you live in florida im looking for 4:10 gears for my 87, did a sas that had 4:10's but the rear has 3:55's
dizdak
Winter Haven, FL
if you have to have a gear swap done, check out Drivetrain Specialists.. they are who i got all my gears from when i had the bronco..
performancelaw
Auburndale FL
I pulled the camper to mudfest and the truck did real good. I think I'm going to keep it like it is for now. Now I need a new transfer case because mine broke something inside of it coming home.
snaponprofile
NY
Ouch! I have 285's w/ 4.10's(3.91 effective ratio) and at 2000 rpms I am around 60mph.
Cv axle
