i just bought a 86 with the 6.9 and I'm having trouble keeping it running. it'll start sometimes and run and idle but other times it'll just crank and crank. also when you give it gas and let off it'll die but if i let off slow it'll stay running. i noticed the hard line coming from the filter housing to the back of the injection pump is leaking on either end could cause my problems also it seems to idle low. where can i get this hard fuel line
