wicked wheel?
88 Ford
San Diego, CA
IMO it would help a stock turbo'd truck too. I had a 1993 that was stock and had the regular wheel and it could have benefitted from the meatier range from 3-10psithe 60-1 wheel provides.
X2 it seems to be a good upgrade for pretty stock trucks to even mildly built trucks too. The more efficient compressor wheel probably allows for a lil cooler boost also...
Jake_IN
West Lafayette IN
Speaking of wicked wheels..
http://fortwayne.craigslist.org/cto/2764160524.html
1994 Turbo Diesel F350 Price Reduced - $4500 (Columbia City )
Date: 2011-12-21, 2:16PM EST
Reply to: [email protected] [Errors when replying to ads?]
1994 Ford F-350 Crew Cab Long Bed IDI turbo diesel
273k This Motor Will Run Forever Have had 0 Problems
180k the motors top end was fully forged
Daily Driven
Only Rust is the rear passenger side wheel well
Its the Size of my Pinky finger
Garrett Turbo with A Wicked Wheel
Stage 2 Injectors
South Bend Clutch Tripple Disk
Compression Plate
Adjustable Waste Gate
5speed
Injecton Pump is turned up 2 cranks
Truck has a 6" side pipe
Both Fuel Tanks Work
All Fluids Have Been Changed
Pioneer Head Unit
Pillar Gauges
Boost, Volts, Temp
Speture Air Filter
New Rear Bumper
Blue Leather Interrior
Sliding Rear Window
Hide away Goose Neck
might consider trade depends on what you have
turbo is a plus
Shoot Me a Text 26oh.2two9.six681
94f450sd
somewhere,ma
I've only encountered turbo surge on trucks with programers that alowed the turbo to boost too much stock to mild the sd turbo is fine bosst it more than it is suposed to and it gets un happy
The sd turbo is good for around 45 psi.the obs psd turbo is good for 26 psi.without head studs the heads start lifting at 40 psi.my obs puts out 36 psi:eek:
89ford
Pierce City, MO
So would it be cheaper to try to find the part number off a obs wheel and go to the dealership?
88 Ford
San Diego, CA
If it is like anything else, the dealer will ream you. Not sure though. Just my opinion...
FordGuy100
Silverton, OR
Yup, I'm sure it would be a lot cheaper to buy from somewhere online rather than the dealer. Ford is very proud of their parts....even when its not their parts (Garrett in this example).
dagreendeville
eustis, fl
ok i may be missing something but correct me if im wrong i have factory idi turbo will the psd compressor wheel work and make a difference or just the wicked wheel? or will they not even fit
94f450sd
somewhere,ma
The psd wheel won't fit an idi no matter what you do.
Get the wheel from ih.can also find them on ebay for short money.or try to find one in the junkyard.
dagreendeville
eustis, fl
that is what i thought just the way i wa sreading it made it seem differant thanks my stocker is fine just lookin for a lil more out of it and wouldnt mind hearin a lil more whistle also
Black dawg
sw mt
why dont you make more than 36psi? Ive seen trucks with stg1s and a programmer make that.
typ4
Newberg,OR
Thanks, now I dont need to explain.:D
