what is this?
ironworker40
NYC Ironworker
nj
anyone know what this is? its on my #1 injector on my 1993 idi. im assuming its for a timing pickup
ironworker40
NYC Ironworker
nj
what type of timing clamp is it for? can you use this meter? I assume i will need another attachment
Thats the original Rotunda timing adapter found on most every engine be it van or truck setup. The van engine had this adapter located on number 4 cylinder injecter. As posted, you can remove it but you will need to replace the line. On the truck engines all you need is the number 1 cylinder hard line from a van. If you have a van engine then you need the number 4 hard line. We really do not need these adapters any longer. I have the Rotunda timing meter that works with this adapter. For no good reason I have terrible trouble when reattaching the hard line to this adapter at cylinder number 1. So I loosen this adapter and then hand thread the hard line to it. Once I feel the hard line is completely hand tight I then tighten the adapter to the injecter. It works...
1mouse3
il
odd mine dont got that adapter or a line long enough to fit it
ironworker40
NYC Ironworker
nj
Okay thanks. I put it back on. Its on The # 1 line. My 6.9 didn't have it. That meter is a cal equipment magnetic timing meter and tack. It has an inductive clamp and a magnetic pickup for the crank. It was my dads. I never used it. Im thinking if a get one of http://www.tooldiscounter.com/ItemDisplay.cfm?lookup=FERV765-01 Ferret adapters i can use it to time a idi. If it dont work i have a snap on digital advandce timing light that should work with it.
